I have experimented by saving a 5 min clip edited in Premiere in a variety of avi codecs and then encoding the clips using cce sp 2.64 using a cbr of 8000 and Tmpenc also.
I have also encoded the same clip directly from the Premiere timeline using the latest plugins from Procoder and Ligos using the same settings for all encoders.
On a small screen the picture quality is similar. However, on my 56" widescreen the plugins (Procoder edging out Ligos) looks great, while the cce and tmpg look a little grainy and blocky. Not to clear.
So I assume the extra step involved with cce degrades the video quality enough for it to be noticable on a big screen. I think overall that cce is a good encoder but is there anyway I can send the complete movie from the Premiere timeline to cce without having to save the file (if you know what I mean). I tried mainconcepts codec with no improvement.
Go and see that link : you will find everything you need.
http://www.abcdv.com/dvtech/dvd/how_to_create_dvd_1.html
Have fun. -
Sometimes it's hard to see the trees for the forest.
Thanks Valentin. Good reading there.
I installed the cce demo sometime ago, before I bought Premiere, so I installed it as a standalone encoder. I will re-install as a plugin and try again. -
OK, I could have told you that.
But since you're using CCE, I have one question. You might help me. I have a problem with the settings described at the URL I gave you, I described it on another post on this forum (see the post "avisynth from premiere to TMPGEnc : transitions become jerky" in the same section). Do you have the same problem with CCE ?
Thanks for the help. -
That's OK, I found a parameter in premiere that was wrong.
Thanks anyway.
Need plugins
By IT learner in forum EditingReplies: 6Last Post: 12th Sep 2011, 09:49 -
Media player verses htpc
By Marccc in forum Media Center PC / MediaCentersReplies: 2Last Post: 15th May 2010, 08:10 -
vd plugins
By uglijimus in forum Video ConversionReplies: 3Last Post: 9th Oct 2009, 06:27 -
Lazer mouse verses standard LED version ?
By cyflyer in forum ComputerReplies: 12Last Post: 5th May 2008, 08:26 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10
