can you edit a mpegav or should i say a AVQSE01 DAT FILE looking 4 a way to edit the intro of any given film if so what software is required
TMPGEnc will except the .dat files as they are, and you can use it to remove parts you don’t want, on load select "All files" so you can see the .dat file.
It is not necessary to convert the .dat back to a .mpg with VCDGear
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 21:29 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 22:38 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 20:31 -
How to descryption video.dat file.
By newbievideohelp in forum ProgrammingReplies: 1Last Post: 12th Oct 2008, 23:11 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 23:06
