Whenever I try and modify my links bar under the address bar it never does what I want it ! It just goes back to the same way it was before I try to make the change. I dont know what the hell is going on. I had version 6 but I uninstalled it and its still doing the same thing. Someone please help me if this is happening to you or if you know why this is happening...thanks!
Have you made sure you havent got the tool bars locked?
To check if you have or not go to the View tab up the top then click on Toolbars then see whether Lock the toolbars is checked. If it is just uncheck it then you should be able to move the tool bars around.
Internet Explorer 7 tabs problem
By Nintendo Fan in forum ComputerReplies: 4Last Post: 25th Feb 2010, 18:41 -
Internet Explorer 8 Keep Crashing
By Squid_uk in forum Newbie / General discussionsReplies: 6Last Post: 27th Oct 2009, 17:44 -
Internet Explorer 6 problem on Windows 2000
By edong in forum ComputerReplies: 17Last Post: 23rd May 2008, 00:04 -
something wrong with internet explorer
By ssaamm in forum Newbie / General discussionsReplies: 9Last Post: 5th Oct 2007, 07:28 -
How can you get rid of Internet Explorer?
By video_enthusiast07 in forum ComputerReplies: 8Last Post: 10th Jun 2007, 18:05
