  1. Ok Iwas told to try this program to solve my sync problem.(plays fine on computer bu tnot on dvd player.) But when I try to download a mpeg files it tell me its not compliant! All my files were converted with tmpenc and they are all vcds I choose new vcd but wont let me download any file what the problem?
    I also tried avi2mpeg (bbpmep) but same thing happens it wont allow me to download anything it always gives me an error and then shut the program down!
    Any help!
  2. Have you downloaded the patch from Ulead?
    This is odd because I use TMPGenc to encode my MPEGs and then author in the DVD Movie Factory.
    There are some other VCD templates available, maybe you should download one and try that?
    It also might help to try making a short SVCD to see if that works. It might help isolate the problem.
  3. What are you trying to burn, a VCD on a CD-R, or a VCD on a DVD-R?
    If you're trying to make a simple VCD, then using the default VCD template in tmpgenc should work perfectly. If you're trying to burn a VCD or any mpeg-1 file on a DVD-R, DVD Moviefactory will not accept any mpeg-1 file without re-encoding it.
  4. I make vcds on cd-r (or cd-rw). I used the vcd template in tmpgenc but still have those bugs!!!!!!!!!!!
