Ok.. I am sorry if this the answer to this question is stated anywhere else, I'm sure it is.. but I cannot find it for the life of me..!
Can you convert DVD to MPG even if you don't have a DVD-rom on your computer??
I tried this some time ago, and my pc could not read the DVD. Is it possible to convert if you do not have a DVD-rom on your pc?!?
I would appreciate any info given.. i've been curious about this for the longest time!!
Sean
Simple answer - No.
To convert you need to read the VOB files from the DVD and then start the conversion. On a PC somewhere you need a DVD-ROM to get these files. You cound send the VOB files from a PC withe a DVD ROM to another without, but these VOB file are very large (1+ Gigabytes)
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 02:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 12:15 -
Embarassingly simple capture question
By eclipse95 in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2007, 14:12 -
Simple Question: True or False?
By jcm0320 in forum Capturing and VCRReplies: 10Last Post: 23rd Aug 2007, 23:33
