  1. when i open a movie it says:
    Audio stream has unsupported format or compression type.
    This program supports only PCM audio format with sample rates: 11025, 22050, 44100, 48000.
    Then I have to click OK
    After clicking OK
    Then it says:
    Encoder failed to decompress AVI video Stream
    Possible reason: Can not find appropriate video codec.
    AVI file may be corrupted or use unsupported video compression format.
    Please select valid input AVI file.
    So, what does this mean. I downloaded the demo version.
    Please help me out.
    I'm trying to get my movies on VCD tonight.
    I'll really appreciate if you guys help.
    P.S. i downloaded my movies from Kaaza but I don't think that has anything to do with it.
  2. You most likely have compressed audio. What is the source file? The source should be AVI with uncompressed PCM audio. If you file has compressed audio, you can convert the audio to PCM, or find a codec that will decode the audio on the fly when encoding. If the file is a Divx, then you have to install Divx (mpeg-4 codecs). Also, if it's Divx, you will most lily run into several video problems as well...
  3. Banned
    Jun 2001
    UK
    Don't support anything does it
    I suggest you download and install the Nimo codec pack, then at leased you will have the audio and video codec's required, then I would use TMPGEnc instead of Lingos ??
    As for Kazaa, your right... its has nothing to do with it unless its a fake, but that's another story for the anti Kazaa brigade
