Can downloaderd file be ran through programs like svcd to get thr quality up a little (mostly on those 150 to 250 size files?Also I've encoded a few movies before an I was wondering what are those pupleish looking blocks that sometime come up then go away??
If it looks shabby when you download it, you can make it look just a hair better (but not much better) using various smoothing filters. Barely, and I mean just barely.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Sometimes the SMR (Angel Portion) codec causes this problem, if you have it installed remove it.Originally Posted by oly19
Also during conversion with program like TMPGEnc you need to higher the VFAPI plug-in plugin settings (DirectShow)
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectDraw" and select higher priority, do this several times until its at the top with a value of 4
Apart from that, if the source has them (CAM movies) then there is not much you can do, any filters used would make the rest horrable.
Fairuse Wizard - Purple Line In Some Videos
By Simmons in forum DVD RippingReplies: 8Last Post: 26th Mar 2011, 11:18 -
Purple Screen of death
By Jericho14 in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2010, 05:40 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 17:38 -
Playback on computer: Purple Haze
By tempac in forum Video ConversionReplies: 7Last Post: 13th Mar 2008, 17:00 -
Colors getting purple after conversion
By vertical in forum Newbie / General discussionsReplies: 3Last Post: 5th May 2007, 23:30
