TMPG Freezes With Some Films!
I Can Play The AVI Normally From Any Windows Application..
Then When I Try To Decode It In TMPG It Freezes!
Some AVI's Work No Problem> Fine..
But It Hurts When The Other (Part 2) Of The AVI Won't Decode ?
Is There Anyway To Correct The Original AVI, So It Will Decode?
Your Help In This Matter Is Highly Appreciated.
Thanks In Advance
CGN
Check this out, it might help! It helped me thanx to KingJohn
http://forum.vcdhelp.com/viewtopic.php?t=99192&highlight=
Start Vdub, load your avi, then select scan for errors under the video tab
If it finds errors save another copy of your avi
If Vdub gives you an MMX error than use vdub-mp3-freeze.exe
Not sure of the link, think it was on www.doom9.com or .net
[/url] -
Thanks!, Who Said You Can't Get An Answer In 5 Minutes!!
Thank You Very Much KingSeti
& Thank KingJohn
For The Info Also....
One Thing Also,
I Downloaded Virtual Dub...
Ant It's Saying You Dont Have Correct Codecs Installed ?
Where Can I Get The Codecs ?
Error Message:
couldnt locat decompressor for format MP43
virtualdub requires a video for windows compatible codec to compress video
Best way to correct this avi's audio
By striker9 in forum EditingReplies: 3Last Post: 4th Nov 2010, 11:42 -
Correct size Resolution for AVI
By Sliztzan in forum EditingReplies: 45Last Post: 25th May 2010, 10:01 -
AVI Freezes up
By surffx in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2010, 05:49 -
Avi index error in vdubmpeg2 - how to correct?
By yoda313 in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 20:44 -
how to correct the aspect ratio of AVI
By edong in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2008, 18:04
