you know that none of those editing programs can prouduce perfect quality vcd as TMPGEnc does. so how do you make them work togather. say i have edited video with ulead or mgi or adobe, and i want to encoe it using TMPGEnc, how is that done. do i have to save it to avi in any of those programs and then convert it using TMPGEnc or can TMPGEnc work as a plugin for any of those programs.
and if i were to create a better quality vcd, should i caputure at higher resolution let's say 480x480 or any other size or should i just stick with 352x240
You can install a Avisynth Premiere plugin and frameserve with Avisynth to TMPG. There is no Video Studio plugin and I don't know anything about mgi.
http://www.videotools.net/guides/guide_premiere_tmpgenc.php -
you could export the timeline as a standard avi using a lossless compression codec i.e. picvideo, this gives a file as almost original quality but smaller file sizes, then encode as normal using TMPGenc
I use both Ulead Video Studio 6 and TMPGEnc. What I do is edit my movies in Videostudio, write them as DV avi file and then create the final mpg file using TPMGEnc
Works like a charm, I know, it's a bit more work than frameserving...
cheers
LeoEquipment:
Athlon 1700 XP system
512 Mb RAM
Geforce 3 Ti500 64mb
1x 100 Gb hard disc (IDE)
1x 40 Gb hard disc (IDE)
1x 40 Gb hard disc (firewire)
TmpGenc Authoring Work Shop 4
By pepegot1 in forum Authoring (DVD)Replies: 0Last Post: 1st Apr 2010, 19:43 -
Ulead video studio 8 help
By the big man in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2009, 17:02 -
Does TMPGenc Plus 2.5 work on Vista Ok?
By leegutcher in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2007, 08:22 -
Ulead Video Studio 7 SE
By uricktam in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 12:14
