do vcd players play them
Actually I meant ask virtualis. micheal used to only recommend vcd players for vcd playback and recommended against dvd players. but that was a along time ago (maybe 10-12 months ago). i recommended dvd players back when the chineese were flooding the market. dvd players can pretty much handle the SVCD challenge.
so the answer is probably no...vcd players will have a hard time with svcd. try a cheap dvd player and you should have no problems playing vcd/svcd formats.
thanx...if i convert a file to mpeg2 does it make it better quality???
if you're converting from mpeg1--noOriginally Posted by whitedawg
if you're converting from a DVD rip or other high quality source to mpeg 2, then you will get better quality than converting to mpeg1what are you askin' me for...
I'm an idiot!
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
