Can someone help me plase anytime I rip a dvd to vcd I always get a much lower volume of the vcd can someone help me correct this please.
A common happening.If you encode via TMPGEnc, try the following:go to Advanced,select Audio Effect,double click on it,select Change volume, open Normalise to 100 0r 150-that willenhance the volume.You can listen to your result using the Player in the same location.
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 11:39 -
Bumping Up the Volume
By solarblast in forum AudioReplies: 1Last Post: 10th Dec 2008, 22:46 -
need a GAIN in volume
By volam in forum AudioReplies: 1Last Post: 18th Mar 2008, 17:32 -
Volume normalizing
By grandsire02 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 11:01 -
adjust the volume
By volam in forum EditingReplies: 9Last Post: 1st Mar 2008, 19:19
