I have 40+ VCDs and I'm wondering. If I buy a DVD Writer, can i put VCD's on them. I mean DVDs hold 4.7 gb of stuff right and VCD's hold 800mb
So 4700mb divided by 800mb = 5.8
So c what I'm wondering is can I put 5 movies on 1 DVD at the same quality (no reencoding) and have them as 5 different chapters so I can put them in my DVD player and watch 1 of 5 movies.
I hope someone understands this, if so reply
Yes, you can, but there are a few problems.
First, the audio should be 48Khz and not 44.1Khz. This can be converted fairly easily. Then, you have to find an authoring software that will support mepg-1 and at the same time not convert the audio to PCM. -
You are looking at many, many, many hours of work. Most people that try this ony get about 2-3 movies at max (fair quality). Then you have to ver-come the problem of your movies being out of sync. Good Luck....
PAL -> NTSC DVD Writers?
By tac7 in forum DVD & Blu-ray WritersReplies: 4Last Post: 2nd Aug 2010, 21:34 -
Sony and Optiarc DVD writers
By anfield7 in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Oct 2009, 22:44 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 01:52 -
Better DVD Writers
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 13:51 -
Buying 2 SATA DVD Writers
By mis3 in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Aug 2007, 22:08
