  1. Please help.Ive downloaded some files recently and when ive tried to encode them with tmpgnc it wont open them or says not supported.
    These files all play perfectley well in media player.Also virtualbub can strip and save the wav.Is there a reason why i cannot open certain files?.
  2. Just noticed that all the files that wont encode are (smr).So messing about in vcd help i have found a site for smr.There is a patch for encoding smr files with tmpgnc but when i tried to download it the link wont open or has gone is ther anywhere else i can get this patch?.
    Please help
    Dec 2001
    USA
    Try up the priority of directshow in TMPEGEnc. options>enviromental settings> Vfapi plug-in. Up the directshow to about 3 or 4
    right click on it to set the priority.
    May the force be with you.
  4. Thanks Tbear. I followed your post and it works!!.I dont know why but it works anyway.
