I'm using mAC3dec to try and split an AC3 file into 5 separate AIFF files. Only problem is, whenever I click on start to begin the decoding, the program quits and gives an error message of type '1' (whatever that means). So, what do I do? Is there another program that will split my AC3 files, on either Mac or PC?
My system is an iMac G3 with 512mb RAM. I've tried using versions 1.5 and 1.5.1 on both Mac OS 9 and Mac OS X, with similar results. The program does convert AC3 to AIFF/PCV/MP3 alright, and the normalization even works. It's just the splitting that's making it crash... unfortunately, I desperately need to split a file, to get just the dialogue from a particular scene.
sometimes you have to run the "fix" operation first before it will split the dolby digital file into multiple mono aiff files. try that.
bd370 stuck
By mosfos in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Aug 2009, 21:05 -
DVD Stuck
By tvlreject in forum DVD & Blu-ray WritersReplies: 15Last Post: 2nd Dec 2007, 21:39 -
stuck with only one HD channel
By rallynavvie in forum Media Center PC / MediaCentersReplies: 4Last Post: 1st Aug 2007, 14:32
