8) I have a movie in MPEG format , which I want to convert to AVI (Divx !!!) but Virtualdub says it is a format it doesn't recognise. Plays ok in WMP so must be ok
Any ideas how I can convert it thanks
Calibra
tmpgenc is said to be best converter.
http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860
describes the settings that will avoid black screen problems while converting. -
Man, are you sure that you have MPEG ?
It may be MPEG2 with 'mpg' extention.
In this case VirtualDub definitely will not take it. -
One file has.MPG the other .MPEG how do I know if it is MPEG 1 or 2
Does it make a difference trying to convert to AVi (DIVX)
Thanks -
Try TMPGenc. If it does not take it than it's most likely MPEG2.
You'll see the massage.
Of course, it's different from MPEG1. MPEG2 is used in SVCD. -
If you have Power DVD you can play it there and right click when you are playing the movie and select Show Information. That should tell you the video format, bitrate, audio format and bitrate, etc. Also, if it is a mpeg 2 then you can't convert it to DivX with VirtualDub.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 23:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 10:08
