I used to be able to rip a DVD in 10mins but now it takes 30+ mins. Could this be becaue my transfer mode is PIO4. If so, how can i change it to DMA if it will make it fast again. Or is it another problem.
It is most probably related to the Pio mode. Which OS are you using?
The Dutchman -
As far as I know; Win XP should automatically enable DMA for your harddrive(s). You can check in the system folder if DMA is enabled.
The Dutchman
BD Rebiulder Pretty Smart
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 27th Jan 2010, 17:07 -
Get Smart backup
By Shermanbay in forum DVD RippingReplies: 26Last Post: 12th Nov 2008, 00:54 -
GET SMART no copy
By shoesss in forum DVD RippingReplies: 3Last Post: 7th Nov 2008, 10:48 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 17:48 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 02:15
