Hi,
I converted two divx files (two halfs of a movie) to MPEG1 using TMPGEnc 12f with the intention of playing them on a DXR2 card. I did both with exactly the same settings, VCD template (NTSCFilm) and didnt change anything else except the motion precision to high quality.
Now the second of the two files plays ok on the DXR2 but the first will not. Both however play fine in mediaplayer. I used the software "Mpeg Properties" and the first file has a extra audio tab for the file where as the second one does not (I assume this is causing the problem?).
Any suggestions as to what might be the problem greatly appreciated.
MaSo
Results 1 to 1 of 1
Bizzare problem capturing - NEWBIE
By Aarell in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 10:38 -
Double Layer Issue That Is Beyond Bizzare..I think I killed the burner
By mrjoelabs in forum DVD RippingReplies: 5Last Post: 1st Sep 2010, 08:49 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Bizzare iPod Behavior with converted MP4 - help!
By cosgrove in forum Portable VideoReplies: 0Last Post: 4th May 2007, 09:08
