is there a way to rip my vcds to a mpg file?
If you get your disk and open it up there should be a file called mpeg something like that. when you open it up there should be a dat file inside it. If you get vcdeasy it should be able to convert that dat file to a mpeg1. Its worked once for me and once not. I dont know if it work for sure, but it might.
Get vcd gear version 2.0...
Open up vcdgear and in the drop down, you will need to select dat->mpeg, go down to load (make sure your disc is in your computer), open up the mpegav folder. In it there will be a dat file(AVSEQ01). Now, it will automatically ask where you want to save it... Be sure to change the save as type... if not, when you select start, it will tell you that there may not be enough room. The reason for this is because, if you look at the type that is automatically selected, it says vcd, which you can not save it to the vcd, you need to save it somewhere on your computer. This should work. VCDGear is what I use for changing dat to mpg, and it plays good too.
Just copy the .DAT file to your hard disk and rename to .MPG, as it already and Mpeg file.
Rip DVD titles to MPG files?
By Asterra in forum Newbie / General discussionsReplies: 4Last Post: 25th Dec 2011, 06:09 -
dvd rip.mpg
By moviebuff77 in forum Newbie / General discussionsReplies: 4Last Post: 24th Aug 2009, 19:51 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
Rip a DVD to a MPG file with selectable subtitles
By jjulio1 in forum DVD RippingReplies: 3Last Post: 1st Feb 2008, 02:24 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
