I have the following on my computer and want to burn it, it looks something like this:
AUDIO_TS folder with nothing in it.
and
VIDEO_TS folder with the following in it:
VIDEO_TS.BUP
VIDEO_TS.IFO
VIDEO_TS.VOB
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_0.VOB
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
VTS_01_4.VOB
VTS_01_5.VOB
Now is it as simple as draggin these two folder into Toast with DVD seleted?
Could it be this simple, maybe but I thought I should ask first. Also the while thig is 4.36 GB in size. and why is there nothin in the Audio Folder? Will I have no audio?
Thanks in advance for the help.![]()
EarlyGrace
that should work just fine. when dvdsp multiplexes a dvd file it usually comes out with a video ts folder than has all those files in it and the audio ts folder is always there and its empty, don't know why but it is, mine always are and the video is always there.
DVD players want to see a Audio_TS folder even if it is not needed. This is really a necessity for most players to see the disc, don't worry about it.
Depending on the brand of DVD-R you're using, it may not be keen on the 4.36. My burner sees Apple branded DVD-R as having 4.4 gig available, but the DVD-RW I use it only sees 4.3 gig.
Thanks for all the help, but one other question,
I dragged both the Audio_TS and the VIDEO_TS files into Toast while in DVD burning option under the other section of toast. I then burned the disk, it took 55minutes at 1 times onto a DVD-RW.
I have yet to test it in a Standalone DVD player, but so far it was not reconized as a DVD by the Apple DVD player on my G4. Is this normal?EarlyGrace -
Weird, the DVD-RW that I burned will not play with the Apple DVD player in my G4 but will play just fine in both my Stand Alone DVD players, I guess Apple just does not support it.
EarlyGrace -
When making a DVD in Toast: Before you drag the Video_TS folder onto your toast window (assuming you have already selected DVD from the "other" menu), you must select "New DVD" from the lower left corner of the Toast window.
This way, you specify that you are burning a DVD for video playback as opposed to a generic UDF data disk.
If you don't select "New DVD", then your standalone player will not recognize the disk.
You don't need the Audio_TS folder unless you are creating an Audio DVD, which you are not because it is empty. You can discard it without consequense.
Problem burning subtitles and movie to DVD with Toast
By Akominatus in forum MacReplies: 40Last Post: 14th Apr 2013, 14:28 -
Burning a DVD ripped with MTR without the Toast application
By FilmLabAsst in forum Newbie / General discussionsReplies: 1Last Post: 20th Sep 2010, 11:58 -
burning a DVD in Toast
By lalilyman in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2010, 22:11 -
burning clips with toast
By 3mselect in forum MacReplies: 6Last Post: 29th Oct 2008, 12:54 -
After burning in Toast: subs: no and yes.
By Levina in forum MacReplies: 7Last Post: 13th Apr 2008, 16:50
