since VCD has the audio option likes
left channel, right channel and stereo
is there any software that can use to capture only left channel and convert it to mp3 or other format?
I need them urgent!
extract the sound using virtualdub or tmpegenc mpeg tools and then use an audio editor like cooledit to extract just the left channel.
kwantum
can give me the link coz I can't find those software
please help!
urgent -
http://www.virtualdub.org
http://www.tmpgenc.net
http://www.syntrillium.com/ -cool edit
you must not know how to use a search engine
As to your problem, since you didn't tell us what your trying to accomplish i can only assume that you have a bi-lingual vcd(left side is one language-right side is another). The process of converting this is not very easy. Matter of fact, for the average newbie, it is extremely hard. Easiest solution? just unplug the right channel while you watch your vcd, or turn the balance all the way to the left.
Here's the low down on what you need to do, if you were to convert it.
1: In tmpgenc use mpeg tools to extract the mp2 audio file out of the mpg (demultiplex)
2: Open the mp2 file in cooledit and remove the right channel (copy the left channel over so that it is stereo.
3: Save this file out as an uncompressed wav.
4: Use tmpgenc to reencode this wav to an mp2, (using the <Audio Only> instead of <System stream (video+audio)>
5: re-multiplex this newly created mp2 file back into the original mpg in tmpgenc with mpeg tools <multiplex>
--On a side note, do not keep "bumping" your thread. Its not very nice and the mods do not appreciate it at all
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 08:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 13:13 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 18:37 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34
