hey,
after cutting my svcd with dvtool,
i burn the file and it is way out of sync in my standalone player. when i hit slo-mo then play again it syncs up for a second or two then goes back out again.
so i demux with tmpgenc and remux with bbmpeg using the standard svcd template....same problem.
the video is a bit choppy and the video is out of synch.
what are the best delay settings to use in bbmpeg, and where should i enter them.
thanks in advance
This isn't a delay problem. This is an authoring problem of some kind. You may have too high a bitrate for your player - that's the kind of thing that happens to standalones.
Delay settings have to be set based on what the difference between the video and audio is. The "best" setting is different every time depending on what your source is, but most often, the "best" setting is no delay at all between audio and video - it just depends how you got the audio.
Basically, you have to decide how many milliseconds out of sync the video is, and set up bbmpeg that way.
However, that won't solve your problem - I think you may need to reencode at a lower bitrate.
Audio delay reported in MKV and what to do with it when adding new audio
By pascal in forum AudioReplies: 14Last Post: 30th Dec 2011, 11:07 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 12:50 -
Delay & Stretch Settings in Mkvmerge
By ThreatTV in forum AudioReplies: 7Last Post: 22nd Sep 2009, 16:05 -
Audio delay on DV capture
By DrewN in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 29th Dec 2008, 01:04 -
Audio delay.. can anyone help?
By denadel in forum AudioReplies: 5Last Post: 31st Dec 2007, 11:14
