After ripping and encoding From Dusk Til Dawn i've noticed something strange at the
burning stage.
The mpg created is a VCD compliant MPEG 1 file if this is put into Nero for checking *before* the file is cut Nero accepts it quite happily.
However after the file was cut with My Flix 3.05 to fit on two CDs nero reports that
both parts are none standard VCD Mpeg files..even though the original file was a compliant VCD Mpeg 1...why is this?
Also is there an Mpeg editing program that will not change the MPG file so it remains
VCD compliant after it has been cut?
regards
Waylander
Results 1 to 1 of 1
Looking for Win7 software to capture AV-->DV videostream
By bneals in forum Capturing and VCRReplies: 2Last Post: 13th Mar 2011, 21:40
