Ok I was told a few days ago that I could solve my picture sound sync problem (which happens only on my dvd player) by using Audio sync then remuxing with bbmpg. I did a search for Audio sync and nothing came up. ANyones knows?
Thanks!
Results 1 to 10 of 10
Try searching a bit harder!!
These forums and this website have LOADS of info on audio sync problems and their solutions. -
I am using dazzle to capture my avi file. I also used dazzle to convert to mpg for creating my video cd. The dazzle video quality is horrible. I then read on this site to use TMPGenc for encoding. I did this and my video looks better....BUT....now the audio is out of sync. I read more on this site and it said to convert the audio to a wav file with virtual dub and then use TMPGen to create the mpg file. I tried this and the audio is still out of sync. I am lost and am about to return my dazzle capture card and software. I have worked many hours on this and am not getting anywhere. If anyone can help I would appreciate it. I did see a correct gap option in TMPGen but have no idea if this will help and have no idea how to use it?????? Help please????
AnonymousGuest
Is this what you were looking for:
http://www.doom9.org/Soft21/Audio/Synch.zip -
I can't access that link. i did try to look undre the doom9 site and found some information. I don't completely understand some of the directions described but I may be able to look more in that site. Any other links? Thank you very much for the response!
AnonymousGuest
Try going here:
Then scroll down to the Sync.zip file. Right click and do a Save As.
I just tried it and it worked. If not I could email it do you. It is only 56k. -
One possible reason to not being able to download it is if you have a firewall. You must disable your firewall before trying to download the files from doom9.org. Atleast that is what I have to do.
Ok i downloaded that file but where should i put it? I put it with my tmpgenc files? is that ok?
AnonymousGuestIt should be fine there but what I usually do is make a new folderOriginally Posted by hola99
for each one of the "New" stuff I download and put the files in there.
For EX: I have VirtualDub 1.3 AND 1.4, so I have two separate folders,
named VDub 13 and VDub 14. Then, now, this is totally up to you, I put
a shortcut to those exe's on my quicklaunch bar - One click and it
it's there.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Streaming live video with audio to website.
By johnkfraser in forum Video Streaming DownloadingReplies: 7Last Post: 29th Dec 2009, 11:48 -
Recording audio from Flash website
By Ryosuke_Gunma in forum AudioReplies: 3Last Post: 27th Jul 2007, 13:14
