Results 1 to 11 of 11
  1. ok, when usin dvd2avi program i did all the steps, and i open TMPGEnc and go to select my audio file and its there, i go to select my video file.d2v that my dvd2avi should give me, and i do have one, but when i go to select one it says open all files .tpr, .avi, and so on, but when i use dvd2avi software it puts the file form into .d2v, so now i cant select anything for video source, any suggestions?
    thanks for your time
  2. Make sure your DVD2AVI.VFP file is located where TMPGEnc is, or it will not be able to open the D2V files.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. hey i got it, thanks for your input, only thing i want to know is does it really take 5 hours to use TMPG to encode the whole movie?
    Feb 2001
    swedois
    sounds very normal.,.,.it depens on how long the movie is.,..and the system of yours.,.,but it sounds good.,.
    /budbrain
  5. k 5 hours is probably right then, but i thought maybe it would be faster cuz im running an 1300mhz 256mb, so i thought maybe i could be alil more powerful, but if not ill just have to wait 5 hours, if it all works its well worth it
  6. I'm glad if I was of any help, right now i'm about to finish another update to my guide, which should appear soon on the website, so if you have any trouble, the new(er) guide is even more detailed then the current one.
    Best Regards,
    Sefy Levy,
  7. Sefy, you have been great help to me, i finally got my first dvd ripped yesterday!! it takes awhile to encode, but it was worth it for me, i will be looking for your newer guide once you finish, thanks for your time
  8. tmpgenc still cannot open my dvd2avi after adding the dvd2avi.vfp file to its directory. please help me
  9. towdawg, you need the dvd2avi.vfp file, open in both tmpg dif and dvd2avi dir, lemme know what happens
  10. ok, ive got it now,i have the new beta and i had to install that other thingie, but i got it. thanks to everyone, and the creator of this site. it kicks ass man. ur cool.
  11. Hi Guys, i'm glad to hear you finally worked things out! congrats!
    The updated guide is basicly finished, i'm waiting for Baldrick to let me upload so he can update it, should be up in a few days )
    Best Regards,
    Sefy Levy,
