In my "CD" copy of Nero 5.5.4.2 theres a little option in the SVCD creation menu.
Its under the standards compliance box and its called "Encoding Bitrate".
You can either try to fit disc size in minutes or set the read speed manually from 1X 150KBs to 2X 300KBs.
I downloaded the patch to 5.5.9.0 recently and the option is gone.
Now friends are complaining that their SVCDs dont work in their standalone DVD players anymore...they are using 5.5.9.0!
I got scared and reinstalled 5.5.4.2 off the CD.
Anyone else notice this option is missing?
Hi
Which is missing, I just looked and can see "Encoding biterate"
1, try to fit to disk size.
2, user defined (KB/s)
I Downloaded 5.5.9.0 from Ahead
I downloaded the patch to 5.5.9.0 -
I got the patch from Ahead themselves.
In 5.5.9.0 the entire box containing both fit disc and manual options is missing. -
I also downloaded this patch from the Ahead website--lost the abilitity to make DVD's on my new burner. Had to uninstall nero and reinstall it plus the 5.5.8.2 patch.
Its the word "Patch" I am not sure of, I downloaded the full program, which works in Demo mode if you don't have a previous version, or will upgrade your last version. I have always downloaded the latest version and its updated what I had.
http://www.nero.com/en/index.html#download
Free Update from previous versions
Filesize: 11.9 MB (12,570,014 bytes)
Current version: 5.5.9.0
Release date: July 3rd, 2002
Running until: August 31th, 2002
Missing Audio after DVD authoring using Nero Vision 10
By Deerkiller in forum Authoring (DVD)Replies: 0Last Post: 11th Sep 2011, 21:18 -
setting region with AVS and a Nero question
By Willy Bee in forum Authoring (DVD)Replies: 2Last Post: 21st Feb 2010, 22:21 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
which setting should i use
By fruitpassion in forum Video ConversionReplies: 4Last Post: 23rd Aug 2007, 19:58 -
Nero Vision missing VOB
By Tjvelcro in forum Authoring (DVD)Replies: 4Last Post: 21st May 2007, 16:16
