i have a dvd burner and i am looking for opinions on the best software for around $50 that will allow me to convert video formats to each other and then the software will include dvd burning software. i used a tmpg free software off of this site which worked great for converting but now my current software does not recognize it to burn it to dvd. i am willing to pay so if there is a good software that converts formats and burns and even makes dvd backup discs please let me know thanks for any help with personal software experience
1 What DVD burning software do you use that does not recognize tmpge files.
2- Did you use tmpge mpeg2 during the trial period or did you accidently create an mpeg1 file and try to tell your software that its and mpeg 2.
What msg are you getting?
A little more info please before you spend any more money. You must have received good software with your DVD burner. -
i have simple dvd maker. i think i created an mpeg2. the message says that the file format is not supported. i like tmpg and am willing to buy it but i need to be able to write to DVD
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 14:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 09:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45
