is anyone having this problem? toolame and ssrc in tmpgenc don't like any .wav files that are over 2 gigs in size even though i'm using an OS that supports bigger files than that. for movies like green mile and titanic and bigger movies, i've had to disable the external tools and let tmpgenc do the frequency conversion and mpg2 conversion but i hate the way it sounds in tmpgenc. i love the ssrc converter. anyone else have this problem? the other thing i can do is split the movie in 3 or 4 using DVD2AVI but i'd rather not have to.....does ssrc definitely have a 2 gig limit on files? i've looked around and couldn't find any definite answer yet....thanks,
I'm not sure about a size limit with ssrc but why not try it out for yourself? You don't have to use TMPGenc as a gui, you can use BeSweet or you can simply run ssrc from a command prompt. If ssrc actually does have a size limit, which I doubt, then just resample with another program other than TMPGenc. You can use virtualdub or just about any other wav editor.
Problems about aac audio in TS files
By ihmcjacky in forum Video ConversionReplies: 4Last Post: 30th Nov 2010, 02:24 -
Losing audio when i convert a 2 gig mp4 bluray to dvd with nero vision
By pkath123 in forum Video ConversionReplies: 0Last Post: 7th Nov 2010, 17:48 -
Avisynth "ssrc resample audio" help
By DaneClark in forum Video ConversionReplies: 0Last Post: 11th Jul 2009, 00:50 -
How many 4.7 Gig DVDs may fit into 500 gig HDD?
By Bronx in forum ComputerReplies: 11Last Post: 24th Apr 2008, 10:40 -
How do I seperate 2 discs froma single dual layer 8 gig VTS files
By xkeots in forum MacReplies: 3Last Post: 11th Nov 2007, 11:48
