I have a mpeg that is 1.2gig and I am trying to split it in half to fit on 2 cd's. When I select the first half and run it (about 1 hour long) it stops at about 32 minutes. I read that I may have a bad spot that is stopping tmpgenc. Is there any way I can fix this problem. Thanks.
Results 1 to 14 of 14
Unfortunately, the only way to fix that bad spot would be to load the mpeg back into TMPGEnc and re-encode it.
You could try the source range to encode just passed the error, but TMPGEnc might not let you split after the bad spot either. -
Could you tell me what steps I would take in TMPGEnc to reencode it? Sorry, I'm new to this whole thing. Thanks
Well I would first try and split the movie after the bad spot, to see if you can get past it, if that failed then you would need to re-encode all.
Just it the Browser for video source like you would if it was an AVI, then load a VCD template, and hit START
If you were able to get past the bad spot, you only need to re-encode just passed it, so hit the settings > advanced > source range -
Skip,
make a note of the frame number (or movie time) that Tmpegenc chokes at; under mpeg tools>cut&merge to split the file into two mpegs with
one ending just before the problem area and the other starting just
after. Later, if you can, go back to the missing source and reclaim
the error section. If you are using mpeg 1 this is easy with Virtual Dub (see guides on left hand side), however if using mpeg-2 you may
have to frame serve. -
Originally Posted by offline
Originally Posted by KingJohn
back to MPEG in just a few minutes. Once this is merged back between
the two original split files, under tmpegenc, the video is
back complete and error free (..or almost complete.)
Whatwith that?
Oh and this is for you->hehe.
Try running mpg file thru VCDgear with FIX ERRORS checked. I've had success with this when TMPGEnc choked on some files.
As for taxing: We here in Canada are close catching up to you Aussies. -
Originally Posted by circleking
I apologise KingJohn, and I have no excuse. I was gone for a bit and haven't even checked them yet. Sorry.
Do you have the popup switched on, it alerts you everytime you visit the forum.
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 21:25 -
TMPGEnc MTS to mpeg-4 problem/question
By Justice37 in forum Video ConversionReplies: 0Last Post: 11th Aug 2010, 16:30 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18 -
cutting an MPEG
By php111 in forum EditingReplies: 3Last Post: 7th Jan 2008, 08:32 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10
