I have been trying to make a simple copy from a vcd, and NEro won't allow me to. This has never happened to me before, and I don't know what to do to get past it. I am sure there is a simple solution to this problem, but I am a newbie and I don't know what to do! I appreciate all the help anyone may be able to offer!
budgirl357
You did not say what error message was, if any, Nero gave you and
what exactly the result was when you attempted to copy the vcd.
If your burner is supported, try CloneCD. It is simply the best. Other than
that a proggie called BlindWrite does an excellent job. Both have
full working demo's available on the net. -
you can also try to extract the .dat file with isobuster and then make a new vcd
#videohelp on dalnet! -
How do I extract the dat? I would appreciate it if you would tell me how this can be done!
budgirl357 -
Click the "how to ... convert" link over to the left.Originally Posted by budgirl357As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
1, load ISObuster (WinISO.v5.3. is good)Originally Posted by budgirl357
2, load bin/iso/? into program
3, select iso or .dat file in list and select extract
You now have a .dat file, this can be used in most programs just like any .mpg file, but if you want to convert it to a .mpg use VCD Gear
Why do you have a problem, if you want a copy of the VCD a disk to disk should work fine.
store bought dvd won't play in laptop or pc, can't copy
By ghola in forum DVD RippingReplies: 11Last Post: 8th Mar 2012, 17:17 -
DVD player's copy protection won't even let me rip home movies.
By Brian. in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th Mar 2011, 16:12 -
DVDFab 6 won't copy all files...
By takearushfan in forum DVD RippingReplies: 4Last Post: 20th Dec 2009, 14:49 -
Nero freezes when trying copy dvd
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2009, 04:30 -
CD Copy with Nero Fails after a few burns
By kadzbiz in forum MediaReplies: 7Last Post: 5th Feb 2008, 20:46
