  1. I have a problem when I burn my VCD. In my Pioneer 535 and in my RSQ VCD player the image is not complete, the left side of the screen appear moved (i.e if the subtitle starts with “THE” only apear “HE”) and truncated.
    I use Nero 5 and before to burn the CD I was tested the VCD image file with the nero Image Drive and a software VCD player and everything looks and works fine. I use to encode the TMPG encoder with the NTSC template that comes with TMPG.
    Any of you can help me???
    Thank you all in advance
    Alejandro
    afibanez@hotmail.com
  2. I know this doesn't answer your question but can Nero 5 Image Drive u mention load cin/bue files for viewing as well¿
  3. afibanez,
    Is the whole image shifted to the left or is it just that the left hand side is cropped? Look closely... Is there some cropping on the right, top and bottom as well?
    It is normal for a given DVD+TV combination to crop off about 5% of the sides...
    If you download and burn the demo VCD available on the VCDImager site, you can measure the degree of cropping that takes place.
    rayjr13, I don't know about Nero but you can use daemon tools to mount CUE/BIN images as virtual drives: http://www.daemon-tools.com
    Regards.
    _________________
    Michael Tam
    <font size=-1>[ This Message was edited by: vitualis on 2001-08-07 08:32:40 ]</font>
  4. Thank you Michael, but i don't know exactly if the other sides (rigth, up and down) have cropping too, because my video file does not have image in the other borders,
    I need to try with another file in order to respond your question.
    RayJr,
    At this moment i can't respond your question with a total certainty but i need to test it this nigth whem i'm in home.
