  1. I'm new here and have tried to open virtual dub and it tells me that Virtualdub has caused an error in VIRTUALDUB.EXE. and that virtual dub will now close. I've tried to uninstall it and reinstall it but it says the same thing. I want to convert some dowloads and can't continue untill I can get virtualdub to work. Please help a newbie!
  2. Banned
    Jun 2001
    UK
    Scan your computer for virus's first, then download a new copy from the author's site only. http://www.virtualdub.org/index
  3. Thanks for the help King John
  4. I ran a virus scan and have no viruses and reinstalled Virtualdub and it still tell me that it has caused an error and will close.
  5. Banned
    Jun 2001
    UK
    Are you using XP Do you have other programs running in the background ? How much memory do you have ? do you have filters in the Vdub folder. Have you installed the SMR codec (Angel potion) if so un-install it.
