Can anyone please help me?
I have a Hauppage WinTV PCI card and am trying to capture from a camcorder.
The problem is that the input to the card is Black and White, however if I connect it directly to my TV instead, the picture is colour.
Can anyone help?
Results 1 to 9 of 9
what input? is this svideo or composite?
it sounds like bogified svideo
THIS IS HARDCORE -
I have tried both, but the cable is an a/v with an svideo convertor on either end as I haven't got a proper svideo cable.
I thought this could be a problem, but is it indeed the case? -
yeah thats the problem, unless those are the $20 svhs-->composite connectors that properly convert the luminance signal (color).
Thanks All !
I'm off to buy a proper svideo cable and stop being a cheap-skate !!
Thanks again. -
I have now bought a proper svideo cable, but no difference! Is there any setting for B+W or Colour?
What else could it be? -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Maybe I´m wrong:
Disconect the normal antenna cable! This fixed the same problem with my Hauppauge card...
Harald -
If you're using the WinTV32 app to capture, there is a control to set the color under configure, but it effects the display from both the Tuner and the composite inputs.
I don't know if the pci version works the same way, but with my usb version if you hit the green button between the channel up and down button (in the wintv2000 app)it changes input between 4 sources. composite 1,2 svideo, and tuner. when cycling thru them the signal will go from color to b/w (I don't remember which is which because i don't have the card with me) try selecting a different input than the one you're using now (if you can select a different one with the pci version).
Capturing from Hauppage USBLive2 WinTV device !!!
By imperialguy in forum Capturing and VCRReplies: 0Last Post: 23rd Jun 2011, 17:13 -
Converting Hi8 for Mac using Hauppage WinTV PVR USB2?
By eamann in forum MacReplies: 7Last Post: 6th Aug 2009, 15:37 -
Hauppage WinTV, BTWinCap to Vdub, dropping frames
By elvisish in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 12:03 -
Blue screen when installing Hauppage WinTV 150 drivers from website
By ponyboy in forum Capturing and VCRReplies: 1Last Post: 5th Mar 2008, 23:55 -
Color Bleed on Hauppage WinTV-PVR 150
By TheBladeRoden in forum Capturing and VCRReplies: 3Last Post: 14th Jun 2007, 10:05
