Has anyone use Sefy's templates..If you have i need some questions to be answered.
I want to fit this 89 minute 16 second movie on one CDR that is 700mb and 80 minute. I downloaded some of Sefy's templates a few months ago(March 20002) but I havent used them yet. According to the text that came in the folder I should use SeVCD; cause i have a Sony DVP-S500D and that supports it. There are 4 Sevcd templates; which one should I use for my NTSC tv (Basic, Enhanced,or the films (Basic,Enhanced)? I will change CQ_VBR to 70 and audio at 160K. Is that good? Also if i use the Soften block noise will that make the file bigger? Also I notice the search motion search precision set to Normal and not High Quality, I thought if you have it in high quality it would give a better picture.
very good question fresco
i have been using sefy's template for a long time i prob will never use another template again
they are def. the best imo!!!!
but use the sevcd enhanced template ntsc and you will be able to fit onto one cd
y2flyy -
also you dont have to decrease anything unless the file length is way over 90 mins and I also have found that by even decreasing the quality settings it still doesnt decrease the file size by much very little decrease
you can also use some filters and as fas as i know they do not increase the file size
and what i have found to be the best filters to use is the sharpening filter and the simple color correction filter
these two filters make the movie look much much better
esp d/l movies that are in avi/divx instead of using the noise filter which increasing the encoding time by a whole heep these work wonders trust me
depending on the quality if the source file (meaning the worse the movie increase the settings)
for the sharpening filter increase both bars to the right (15-45 is what i normally use depending on the quality) and this makes the blur go away for a better picture
and the simple color filter just use the contrast (the contrast makes the movie not look so bootleg if you know what i mean, it covers most of the blocks and noise that come from d/l movies) and set it anywhere from 10-15 to the right
do not check any of the high quality settings trust me they dont make that much diff in the output imo they increase the encoding time much too much
like i said those two filters if you try will make a big difference
y2flyy
Video Stream Recording Question (Looking for answers)
By likwid8 in forum Video Streaming DownloadingReplies: 2Last Post: 2nd Oct 2009, 11:58 -
Answers to Windows Movie Maker
By GimpGuy2000 in forum Newbie / General discussionsReplies: 13Last Post: 8th May 2008, 19:00 -
Common questions and answers.
By Faustus in forum DVD RippingReplies: 31Last Post: 27th Feb 2008, 07:21 -
Troubleshooting VGA to TV Problems - Looking for Answers
By nathanhj in forum Newbie / General discussionsReplies: 5Last Post: 17th Feb 2008, 22:00
