I'm joining together some avi segments in virtualdub. The clips seem to have been cut cleanly, because I don't see any repeats or dropped frames. But when playing, as soon as it hits the keyframe that starts the next clip, the audio skips (goes flat) for that split second. Any ideas where this came from? I assume it must be a glitch in the audio from where it was cut. If there's anything that could help fix it, let me know. Thanks.
Sounds like it was not cut at keyframes.
Try loading the first AVI, move to the end, and mark it as end, then click back 1 keyframe and mark it as start, then delete. It might not have been cut at a keyframe.
Part 2 might not have been cut at a keyframe either, so it may need the start cutting at a keyframe.
If the output is going to be a VCD, just encode them both with TMPGENC, the mpeg join with merge/cut might be OK
Annoying 'gap sound' when joining flv files
By KeyMs92 in forum EditingReplies: 2Last Post: 17th Sep 2011, 19:31 -
MP4 Joining Problem.
By nicolasonline in forum EditingReplies: 3Last Post: 7th Jun 2010, 14:06 -
Joining a MP4 video and mp3 sound
By powerkor in forum Newbie / General discussionsReplies: 2Last Post: 4th Sep 2009, 10:22 -
problem joining videos
By goatvideo in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2009, 11:19 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 04:14
