I'm trying to convert a .avi (divx4) but when I use TEMPEnc 1.2i I get as far as 48% and then it says something about floating point error. I then try it in Virtuadub and it says "can't read frame xxxxx" I then proceed to erase those frames and save the .avi again but Virtuadub only saves about 50% of the film with a similar error. Heeeelp please.
sounds like you got bad frames in the avi. you might try to delete the bad ones in virtualdub - but its probably a lost cause.
Hopefully I have solved it. I'm using VirtualDub 1.3c to cut it up into smaller .avi. Then I'll convert all the small clips to mpg and burn the VCD with different tracks.
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 15:22 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 10:31 -
lagarith avi to xvid avi - problem
By phpmysql348 in forum EditingReplies: 1Last Post: 23rd May 2008, 12:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
