help, how do i repair a avi that does not work? or can you? can anybody help, a get a lot of ones off the internet that dont work,
Load AVI into VDUB and select Video > Scan video steam for errorsOriginally Posted by bomartin4
After scan select;
Video > direct stream copy
Audio > direct stream copy
SAVE AVI
Save movie2.avi
If Vdub crashes during the scan you need "vdub-mp3-freeze.exe" to do the same scan, but this time it makes a log at c:\badframes.log which you can use to delete the bad frames (At keyframes) using the highest numbers found first.
If the AVI wont load into Vdub, install the Nimo codec pack, and try again. Also load into TMPGEnc and use the preview.
If all this fails, you have downloaded a fake, next time preview a few MB before you download the whole thing.
repairing a broken AVI file
By p_s_92 in forum Newbie / General discussionsReplies: 27Last Post: 29th Jul 2018, 17:42 -
Fixing / Repairing a MJPG AVI video
By DBennett in forum RestorationReplies: 6Last Post: 19th Dec 2010, 08:24 -
Repairing discs
By moonhoney2 in forum MediaReplies: 5Last Post: 28th Nov 2009, 09:41 -
Audio Sync Problem, Repairing and AVI File?
By JerryRecords in forum AudioReplies: 1Last Post: 5th Dec 2008, 00:38 -
Repairing MKV?
By unknown12 in forum Video ConversionReplies: 3Last Post: 2nd Feb 2008, 17:06
