i have a multimeter so if anything goes bad i can always reset it, I have a toshiba 3107b and nearly plays princo perfectly, i just wanna give it a push
Results 1 to 11 of 11
and adjusting a potentiometer in your dvd player will make princo's play better?
THIS IS HARDCORE -
Maybe he meant putting some marijuana in his Toshiba makes Princos play better?
Or maybe he meant smoking a little joint makes Princos taste better to his friend Toshiba?
Who knows. -
Smoking Ganja makes his music sound much better.
Tweaking the pot by mixing different blends creates different highs (and lows).
I think he might be Princos pusher. -
he may be able to improve its performance...
he may be able to worsen it...
im sure he's able to just buy other cd-r media though.
THIS IS HARDCORE -
Well I am guessing he want't to tweak on the potentiometers (sp?) that control the laser.....
Michael -
its a common myth that playing with the variable pots on a dvd player with allow for high bitrates. This is garbage as the variance refers solely to speed of the carriage which moves the lazer accross. brings it out of line and it will cause more damage as when a dvd/vcd/svcd reaches the middle of a cd it will have more trouble reading without skipping. bitrate is calculated by chips not variance in power.
Tweaking VHS captures
By Cherbette in forum RestorationReplies: 165Last Post: 11th Oct 2011, 10:37 -
JVC DR-M10B dvd pot adjustment
By retrogamer in forum DVD & Blu-ray RecordersReplies: 5Last Post: 28th May 2011, 01:48 -
Pot Player no pan scan ?
By nic3 in forum Software PlayingReplies: 0Last Post: 26th Apr 2011, 04:10 -
Tweaking mencoder options
By acid_burn in forum DVD RippingReplies: 3Last Post: 27th May 2008, 09:59 -
Video Configuration tweaking...
By NHRaider in forum Media Center PC / MediaCentersReplies: 19Last Post: 15th Jul 2007, 15:16
