Hi!
Juz started out in video editing....
Mac G4 400 ( desktop )
512 mb ram...
using final cut 3........
OSX and OS9.......
prob: Is there any way to convert to VCD FAST AND GOOD QUALITY?
I've seen a friend exporting to a movie type ( i think is mov ) then he transfer to his PC and using TMPGENC to convert to mpg and the quality was supppppppperrrrrrrrrrrrrrrrbbbbbbbbb!But i juz cant find the correct combination.... He said he the encoding time is 1:2.......
anyone has any ideas or any faster methods?
cause time = $$$$$$$$
Thanks!
Cheers!
Darence
The best method would be to buy Toast and convert it directly from the project. I would suggest exporting it with Motion JPEG A or B and then converting that into a MPEG-1 stream for VCD use.
Toast is a great encoder(since it is required to burn VCDs anyway) but another good one is Cleaner 5.
Since you have X, a very GREAT quality idea is going for SVCD.
http://homepage.mac.com/rnc/
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Final Cut Pro
By masaeurope in forum ffmpegX general discussionReplies: 7Last Post: 10th Mar 2010, 17:58 -
16:9 in Final Cut Pro
By malibu in forum MacReplies: 2Last Post: 5th Jul 2008, 08:41 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05 -
Final Cut Pro / Soundtrack Pro Link Problem
By scottrwn98 in forum MacReplies: 11Last Post: 1st Jun 2007, 10:36
