  1. When I try to open The Others in virtual dub I get an error. "Cannot determine filetype of D:\The Others DVDRip.avi". I downloaded another version of the movie but its the same error.
    What is this?
    Tiger
  2. Banned
    Jun 2001
    UK
    Can you play the movie ?
    The Nimo codec pack, provides the codec's you need for 99.9% movies, also DivX 5.02 is needed for some
    However if you already installed "All" the codec's, you have downloaded a fake...
    Load into TMPGENC, if the audio does not show up in the browse, its a fake
  3. I have all codecs installed.
    And the movie works great in the media player.
    I dont understand..
    Jul 2001
    los angeles
    It's true, I thought I had a genuine divx5 codec, but when i went to encode it was all black. Try the nimco pack, if you havent. it worked wonders for my situation.
  5. Banned
    Jun 2001
    UK
    I dont understand..
    right click the file and select properties, try to find out what type of codec's are in use.
