can anybody tell me what the best program to do it with??
or can anbody just tell me a program??
that can capture from a Camcorder on to CD??
the "program" will come with your capture card
what capture card do you have ? -
So what you really want to do is to convert your vhs tape to a cd that can play on your computer or dvd player, right? There's a huge range of possibilities here. The drill goes something like this:
1. Hook your vcr up to a capture card (that's installed in your pc) and capture the movie - Use VirtualDub for the capture
2. Convert the movie to mpeg format (or not, if you captured directly to mpeg) - Use tmpge for the conversion
3. Burn the video cd. - Use Nero for the burn
Now go read a whole bunch and get the other 10,000 details!!
Done capturing my VHS, what now?
By Akerhage in forum Video ConversionReplies: 31Last Post: 27th Jul 2011, 09:37 -
capturing vhs to hdd
By zulubase in forum Capturing and VCRReplies: 2Last Post: 20th Feb 2010, 18:00 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 17:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 10:32 -
Capturing VHS to ALL-IN-WONDER Card
By Smack2k in forum Capturing and VCRReplies: 6Last Post: 2nd Dec 2008, 10:20
