Hey,
I just downloaded this movie, and the playback is fine. the picture is good, and its the full movie...It is a DVD rip. but the sound is absent. I tried playing it in Divx Player 2.0 Alpha, but no sound. and when i tried to play it in WMP, it gave me this error
No combination of filters could be found to render the stream.
I right clicked on the movie file, and when to the properties and this is what it said under the details tab for AUDIO.
Windows Media Audio V2, 64 kbps, 44 kHz, stereo (for audio/video)
What can I do to watch this movie with sound?
Do you use Dial-up for internet access? If so, connect to the internet, then open the file in Windows Media Player. It SHOULD automatically go to the microsoft site and download and install the required codec.
Hope this helps -
Ok, went to Windows Media, it downloaded the codec, i now get picture, but still no sound.
Same on DIVX player
Any other suggestions.
It says in the Properties section:
Audio
Bit rate - 64 kbps
Audio sample size - 16 bit
Audio format - Windows Media Audio V2
Video
Frame rate - 29 f/s
Data rate - 89 kbps
Video sample size - 24 bit
Video compression - Divx compression -
Install Nimo Codec. You could use the tools link to the left side of the message to get the link to the Codec.
Need Suggestions for a good Camcorder with great sound quality
By techspark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 8th Apr 2011, 11:34 -
virtual dub playback ok..quicktime pro not so great?
By dullrazor in forum Newbie / General discussionsReplies: 6Last Post: 12th Oct 2009, 22:11 -
The Beatles Remasters - Some Sound Really Great
By Soopafresh in forum Off topicReplies: 3Last Post: 14th Sep 2009, 08:01 -
VOB2MPG WORKS GREAT PLUS HANDBRAKE FOR PS3 5.1 sound fix
By JordonB in forum DVD RippingReplies: 10Last Post: 7th Sep 2009, 21:55 -
Music sound playback is greater than word sound playback
By shknoll in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 13:09
