hello peeps,
I'm converting a divx movie to VCD, i've done a sample and the picture is now a bit pixelated compared to the source, it's a in pal 352x288, the final file size will be about 650mb so i still have a bit more room to play with, how can i improve the pic qual?
thx![]()
You could increase the bitrate, but then it would'nt be a standard vcd anymore, it would be an xvcd. You would have to check that your standalone player was capable of playing xvcd.
Craig -
There are several options:
-Higher motion search (like maximum)
-Noise reduction filter
-Soften block noise
-Longer GOP
-Uniform quantize matrix (like an 8x16 grid) -
how do i change the bitrate?? its all greyed out :[
i h8 being a noob at things
frogmella:
In TMPGEnc, choose Load and then go into the Templates directory. Choose the file Unlock and click on Ok. That will unlock the options so you can change them.
Need help improving the quality of this anime
By Luminous69 in forum RestorationReplies: 11Last Post: 17th Jun 2011, 20:00 -
Improving quality?
By BwanaP in forum Video ConversionReplies: 30Last Post: 19th Jan 2010, 23:03 -
Improving video quality
By rusting in forum Newbie / General discussionsReplies: 10Last Post: 10th Jun 2009, 01:35 -
Improving Video Quality
By pctech@apc4me.net in forum Newbie / General discussionsReplies: 2Last Post: 30th Mar 2009, 19:39 -
[Help] Newbie: improving video quality
By Fredje81 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2008, 08:12
