I have my avi captured and done some editing in premiere and i am frameserving to TMPG. i want to convert it to a SVCD. I am not concerned about file size at all, but only the final quality of the video.
What are the absolute best settings to use in TMPG for SVCD if only concerned with video quality and not file size?
If i load the SVCD Template and i go into configure which is the best rate control mode to use. (ie - CQ, CBR, VBR etc.)and what are the bitrates i should use?
Also what is the best motion search precision setting?
And is there any difference between the output quality of any of the TMPG versions so far (12a - 12i)?
Does anyone use the filters (eg sharpen images and reduce noise etc.)and what are some good settings in them to try?
cheers for the help![]()
In my limited experience I suggest:
2-pass variable bit rate, default settings with padding.
high quality motion search.
10 dc component precision.
224 bit rate for audio
112 vbv buffer size.
The others don't make much difference if your source material is good.If I can be of more help-ask.
Use 12a ...
(Free MPEG2 encoder and best quality if I may believe some comparisation tests)
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 13:05 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 09:14 -
Best settings voor TMPG Express MTS Files to Divx Avi
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Mar 2008, 10:36 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 02:11
