Ripped Shrek and selected "Movie only" option in IFoEdit.
Kept ac3 English Audio stream and stripped to new VOBs.
Opened new VTS_01...ifo in IfoEdit and did Get VTS Sectors, then saved.
Tried to play in IFOedit and says:
"Failed to render to 2 of 3 streams:
video stream
subtitle stream."
Guides say this method should work but I'm wondering if its because there are 2 extra angles in early part of the movie. I've not messed with these so thought they would be OK.
Ne1 had this problem with Shrek?
I don't want any menus or extras, just the movie to play when I insert the disc.
Plz, any help would be really appreciated.
I encountered this as well, cinephile. I don't think it has anything to do with multiple angles, but rather with the way IfoEdit plays and previews.
Installing a DVD player should fix this for you - try WinDVD. -
Thx for your reply.
I have PowerDVD installed and that complained "format invalid" when I tried to play the new Shrek VOBs from HDD.
I have played rips successfully before but never seen this message.
I did a search on this forum and found that you must have "Multi-angle processing" enabled in DVD Decryptor when ripping multi-angle movies. I don't think I did...
Is it likely then that the main movie IFo file I originally ripped is screwed up? And is this what is causing me problems?
Should I re-rip and get IFOedit to Remove Unwanted angles for me?
Cheers. -
OK now successfully created backup.
Even though I had Multi-angle processing OFF in DVD Decryptor it still rips the first angle.
So I used IFOedit to remove the other 2 angles and all menus/unwanted streams and burnt = working copy of Shrek.
However, I've set the Multi-angle option to permanently ON for future rips.
...another lesson learnt.
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
Star Trek TOS Blue Ray Multi Angles
By Scarpad in forum Blu-ray RippingReplies: 3Last Post: 29th Apr 2009, 17:36 -
Shrek killed my dvd decrypter!
By blaqlion22 in forum DVD RippingReplies: 16Last Post: 18th Dec 2007, 17:35 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 11:54 -
Shrek The Third
By boldego in forum DVD RippingReplies: 3Last Post: 13th Nov 2007, 21:10
