In most of the guides I read, it always suggest a resolution of 720x480 for DVD mpeg-2 encoding. However, I know that 704x480 is a valid supported DVD resolution. This is video captured off VHS so it will make no noticeable difference to use 720 over 704.
It's important that I can encode a 24 minute program in DVD mpeg-2 format so that it is also small enough to be burned to CDR media. I encoded the program at 720x480 and it was just over 900 megs. It is my hope that 704x480 will fit. It will be shipped on CDR media and later authored onto DVD media.
Does anyone else out there have experience with this?
Darryl
Why not go 720x480 and just lower the bitrate a tiny amount?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I'd rather not give up the bit rate if I don't have to.
Darryl
Upscaling and proper SD DVDs (704x480/576i)
By gaelsano in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jan 2012, 09:18 -
Is 704x480 with a 16:9 DAR valid for DVD?
By Anonymous344 in forum Newbie / General discussionsReplies: 136Last Post: 5th Jan 2011, 15:11 -
How to convert 704x480 to 720x480 without re-ecnode?
By rogalewski in forum Video ConversionReplies: 18Last Post: 27th Aug 2009, 22:47 -
DV to 704x480 or 720x480?
By Almost Human in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 11th Dec 2007, 20:37 -
Vob File has a aspect ratio of 704X480 in Dvd Lab Pro.
By mlong30 in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 00:24
