is there a program or a way to know what field order a video file has? i'm ripping dvd's and encoding with tmpge to dvd . most of the time its field A but once in a while its B. it sucks wasting dvd-r's .
Bitrate viewer by Telco can tell you the field order. http://www.tecoltd.com/bitratev.htm
Or you can actually just use TMPGenc. Go into the advanced tab and double click on the deinterlace filter. Set the filter to Even-Odd field (field.)
Scroll through the movie and if it looks ok then you have the correct field order set. If it plays a few frames then jumps back a few then your field order is incorrect and you can switch it in the advanced tab.
If you already have encoded video with the wrong field order set you can reverse it using pulldown.exe.
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 03:12 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 22:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 5th Dec 2007, 23:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
