I have been trying to burn some mpg files as vcd, using Nero and apparently evrything is fine. However on 3 of the files i get some awful skipping of the audio - The rest of the files are fine. When i play the files using windvd (from my hd, not from the vcd) they are fine, with no skippin at all - so i guess it's Nero causing the error. Any help as to what the problem could be, would be grately appreciated.
Thanks in advance.
Nero is a great burner, but a horrible encoder. Use something like TMPGEnc to encode, then Nero to burn.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 10:39 -
DVD to VCD problem
By c1steady in forum DVD RippingReplies: 12Last Post: 14th Sep 2008, 18:19 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
