    Jul 2002
    Canada
    ok here's my problem:
    My burner is supported by hardly any software so I like to create my bin/cue files using VCD Easy then burn the with fireburner BUT when I try to create mpeg stills for menus in VCD Easy they come out all screwed up looking. The image is kind of offset like:
    0000000
    -0000000
    ---0000000
    0000000
    and so forth. What program can I use just to make the MPEG stills that will work that I can then take into VCD Easy and do my thing?
  2. I think that TSCV has a mpeg still generating feature.
    PlaiBoi
  3. Go to the VCDEasy website and download the update to MJPEGTools (the part of VCDEasy that makes the stills). This apparently fixes some the still image problems with some hardware players.
    TSCV doesn't make "real" MPEG stills...
    Regards.
    Michael Tam
    w: Morsels of Evidence
  4. hi all,
    i had a similar problem with VCDeasy. i generated numerous vcd compliant mpeg stills, no prob. but then i wanted to do a svcd menu, generated a few good stills, but then the program stuffed up. cant even make a playable mpeg2 still at all!
    so, i went to the vcdeasy website to download the update, but its temporarily unavailable. (for 2 days now)
    are there any other methods for generating simple stills for svcd menus?
    gavin
