  1. I have a question regarding the creation of menus. In Nero, you have the window that allows you to select CD-i application...and the smaller window where to define cursor type, color, etc. My question is, is it possible to make a menu that uses a pointer, and the remote keys other than using the number keys??
    TIA
    Mike
  2. Unfortunately not
