Hi all
I have a file on .avi format and I would like to convert it VCD og SCVD.
What software (freeware) do I need to convert the .avi files ?
Results 1 to 10 of 10
Regards,
Duddi -
Do not for get to get the kwag templates for VCD at www.kvcd.net
Hello. -
and in case of the black screen after conversion look here:Originally Posted by Baldrick
http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860 -
tmpg is a waste of time nero will encode and burn but i dont know if it converts to svcd unless its in mpeg2 format i have never had a prob burning avi to vcd with nero but when i tried to burn to a svcd error came up. bettter off getting the movies from srvers on AOL at least you see what you are getting
yes it can - and with a plugin NERO will even do SVCD (you may download from Nero Hompage), but encoding quality is far away from TMPGenc quality. If there is no need for, I wold never decode with NERO.
What makes you say this, I think it is the best piece of freeware I have ever downloaded, and I think many people on this forum would agree. It far outperforms nero for encoding to VCD compliant mpeg.Originally Posted by videoman882
Craig -
Two of the best programs, in terms of results and usefulness, you will ever download for video work are VirtualDub and TMPGEnc.
The third best program, IMHO, is ScenalyzerLive. It is however not free but the registration fee isn't all that much. -
Nero for encoding and AOL for movies, is it April 1st .
The mind boggles.
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 02:12 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
